Your answer is in here. Search is your friend!!!Purchasing new tires...if it fits, I want to swap the spare "donut" with one of the P215/70R16 tires. Can anyone confirm that it does / does not fit?? I found that earlier Elements does NOT fit but was not sure specifically for '07 EX.
Yes, I agree the Search function is very nice. Thanks also for attaching this "answer" from a 2005 Element...with my inexperience with these cars(?) I was not sure if 2007 fitment was the same as 2006, 2005, 2004, etc.Your answer is in here. Search is your friend!!!
look for threads on stealth subwoofer installs.Has anyone on here done something with their spare tire area other than use it for it's intended purpose? IE, have you modified it and rid yourself of the spare for some reason? I'm in the process of doing so....
i was thinking there's no way you can get all that stuff in the well with the spare still there, so i clicked on the image and discovered i was right, as you had relocated the spare to the roof.A little searching turned up this post; there may be others.
Also I stash the following in my spare well: jack and tire wrench, toolbox; socket set; pump; tow strap; entrenching tool; pair of boots; winter-weight jumpsuit, hat, and gloves; snow-melting kit; blanket; water; MREs; CB radio; jumper cables; and flares.
