Did a few things to the element this week, 183,000m on the element and I only own it for about 1 month
so I am not sure if the plug were ever changed or valves adjusted before
adjusted the valves and changed the spark plugs
  • intake valves within spec .009
  • exhaust valves all less then .009 adjusted them to .012
old plugs were NGK replaced them with Denso
checked the gap on the old and new plugs (Denso 4702 IK20TT Iridium TT spark plug) were about .035, thought it was odd
because everything I found online shows the specs should be gap at .044
so adjusted the new ones to .044 and installed
202812
202813
202814
202815
front and rear struts, front lower control arm, rear brakes, front out tie rods, VTEC solenoid, oil pressure switch,
202816
front
ULTRA-POWER 172135
ULTRA-POWER 172136
rear
ULTRA-POWER 171101L
ULTRA-POWER 171101R
new front lower control arms help out alot
mine were not torn just old 16yr so they needed to be replaced
