Where is the stock subwoofer amp located and how do you remove it? It's in the passenger wheel well right side, correct? How is it removed...
2007 Element EX AWD AT (two!)
Pull the weatherstrip away from the edge of the kick panel, then pull the kick panel toward the inside of the car. Removal of the amp should be pretty straightforward after that.
Cool, thanks for the note - Disconnecting and dropping the glove compartment also helped gain access to the top, 3rd bolt needed to remove the stock amp - Mission accomplished today...🤘
