1 - 2 of 2 Posts
Seems like my 2003 EX has another issue.
Runs rough on and off while I accelerate up to about 40 MPH. Can feel the vibration in the gas pedal. Thinking loose engine mount. I know it's not the rear diff.
Any Ideas?
Thanks,
Matt
:confused:
Try engaging the tranny in neutral and see if the rumble is still there as it would be with an engine mount. If it goes away I would think you could have some torque shudder. You can do a drain and refill 3x's to "try" to eliminate the problem. If the problem persist I would recommend a high friction modifier additive (4 ounce at a time) or lucas tranny treatment (use 14 ounce at a time).
1 - 2 of 2 Posts
