Can I put 07 struts on an 06? I noticed that the part numbers are different along with the spring part numbers being different. (Fronts) If they are interchangable can I then use the 07 SC struts on my 06 when I put either Eibach's or H&R's lowering springs? Is there that much differnce between the SC's and the EX's struts to warrant this change? If I can't or shouldn't use the 07's, should I get new 06's or Monroes, KYB's (if they are ever released). I have 54k on mine now and figured I might as well replace them when I put on the springs.
Thanks
Thanks
