I have given that some thought too. Since I do have an Ody I can take a real close look at it. There would have to be a second switch to make it operable from the rear as well.... From a construction position it will certainly be possible if one is willing to cut and weld...Has been discussed, especially for the rear side windows, but afaik it has not actually been done. You might want to start with Odyssey rear corner windows. Dunno about the current generation, but they used to operate electrically on the EX.
I've started trying to look at options to just put a mechanical extension down the middle of the ceiling/headliner so I can at least just open from the driver seat. Seems like with a mounted bracket and a couple of attached rods, it would be do-able. Just not convinced it would be something I would actually like seeing in there vs an electric power option.Anyone know of a kit or DIY to convert the sunroof latch handle from manual to remote electric on a 2008 EX?
