221 - 235 of 235 Posts
how are you pushing those? 2 channels for the tweeters and mids, and 2 for the door?
Discussion Starter #222
Well that is part 2 of the upgrade, currently the 3" drivers in the pillars are powered by the decks inboard amp, and the doors (front and rear) run off the NVX 4 channel under the drivers seat.
I'm changing both amps (4 channel and the sub amp) to SKAR amps.
I will then run the lot from the new amp.
Of course I will post the upgrades.;-)
active crossover? or straight off the amp? I NEED TO KNOW!!!!
Discussion Starter #224
The 3" pillars wired to the decks amp are using the decks X over, the tweeters in the doors use a passive that came with the JBL separates. The mids are wired thru those same X overs.
I'm going to change that to the new amps on board X over for all but the tweets, I will be using caps on those.
Discussion Starter #225
New pillars installed
Finally got some time to install the new pillars in the Rootbeer
While I was at it I added some more damping to the front doors....
Before...
Discussion Starter #226
And after...added some to the plastic door panels too.
Discussion Starter #227
Then on to the pillars....
Drivers..
Discussion Starter #228
Passengers side.
Note photo bombing Kiwi, and the still to be finished RH door speaker cover.
Discussion Starter #229
Speakers in.
Discussion Starter #230
Drivers side.
Discussion Starter #231
All finished with the grilles installed.
Discussion Starter #232
From the front.
Discussion Starter #233
Now a little tuning and we should be good.
First impressions..much brighter sound stage, more pronounced vocals.
Going to take some tweaking, but so far I'm happy.
you aren't leaving those door tweeters in are you?
Discussion Starter #235
Yes, those Vifa tweets are crossed over differently, so it's all part of the plan.
