I have a 2003 Element with low miles, in great condition. I'm considering purchasing a teardrop trailer. Does anyone have suggestions for a low weight trailer (1000 lbs or less) that can easily be towed over mountains without distressing the transmission/motor. Thanks.
Just wanted to mention that I just towed a 420lb trailer with a 650lb motorcycle and 2 spare tires and other gear (50lbs) behind my 2005 Element AT from New England to Florida and back. 3000 miles total.I did carry about 200lbs of gear inside plus me and my 50lb dog... It pulled the weight very well, but would not recommend using cruise control. It will downshift at every hill and without it, I could anticipate the hills and keep the RPM's around 3k. I did drive through the Smoky mountains on the way back and there was definitely downshifting on the roads there. I achieved about 20 mpg overall.
Discussion Starter #5
Thank you, this is very encouraging.
2007 Element EX TRP
Not a teardrop, but towed a 1500# trailer from GA to AK (yes, ALASKA!) with no issues, just be smart about ups and downs as bctours mentioned. If you are going to tow on a regular basis, the lighter the trailer the better for longevity. There will ALWAYS be gear weight added to empty trailer weight. :cool:
