Im not going to lie this wasn't a very easy mod to do.be prepared for some work and patience.the hardest part is the aiming.making sure they are spaced apart good,and level.The bi-xenon is a must have for the Element.I know alotta guys do just the single.And it would suck with just low beams.The high beams on the tl projectors are amazing. Parts list: Tl projectors
ZkW lenses from BMW or replicas
relay harness for ballasts make or buy them.
Ballasts
hid d2s bulbs
8 bolts and nuts i used lock nuts
high grade silicone for sealing headlight or use nissan headlight sealer from dealer.
jb weld for bolt threads and attaching shroud.
I would recommend going to
www.theretrofitsource.com and join the forum and do alot of research before doing this to your headlights.It is very easy to screw this up. The parts are going to be expensive if you want good stuff thats gonna last.
Tl projectors 175-210.00
shrouds 20-70.00
lenses 50-100.00 Highly recommend these lenses!!
bulbs 40-80.00 for good ones
ballasts 40-100.00
wiring,relays,paint,misc. 30-50.00
As you can see it's also easy to wrap some money in this project.I bought mine here and there over the months.And did research.There is no sense in spending a bunch of money on high quality parts and doing a crappy job.
