1 - 2 of 2 Posts
Moderator
Headlight restoration kits are easy to use and they're much cheaper than going to a professional or replacing the headlight housing entirely.
Are your headlights covered in a dull-looking, hazy or yellowish film? Not only does it make your car look ratty and older than it needs to, but it can also be a serious safety issue. Having foggy headlights impacts your safety if driving at night.
That foggy appearance on your headlights is caused by repeated exposure to the elements: weather, UV rays, etc. Fortunately, there are many headlight restoration kits out there that can help make your car look as good as new and improve your visibility at night. Headlight restoration kits are pretty easy to use even if you have no car detailing experience, and they’re much cheaper than going to a professional to restore them or replacing the headlight housing entirely.
Comment below if you're going DIY!
Read more about the Top 10 Best Headlight Restoration Kits at AutoGuide.com.
Indeed, even the best headlights succumb to the desolates of time, introduction to the components and concoction contaminations, with the most noticeably awful guilty party being bright beams from the sun. The vast majority just call up their seller, or head out to a vehicle parts store for substitutions, and relying upon the vehicle make and model, that can run you into the several dollars.
Peruse increasingly about the Top Headlight Restoration Kits.
1 - 2 of 2 Posts
