is there a turbo charger that will just bolt on? any info on parts and part numbers would be great! THANX!!
Well any turbo will bolt on if you have the right manifold. I'm not sure there are any kits that were designed specifically for the Element, but it is the same K-series foot print that the RSX had so one of those kits would get you close. Aside from the kit you'd need to make sure you had the right tuning done. So it isn't just a bolt-on affair.
1st Gen Acura RDX is a turbo K motor
