EOC Rank: Seagull
greetings....i have 2004 element, horrendous fan noise coming from dash...so i figure my mechanic has to pull out entire dash, might as well see if i can update gauges with led/brighter option....same for headlights...........wondering if anyone has found suitable aftermarket kits.....thanks
I have 04 LX also but pulled the instrument cluster from an 07 SC. The fitting are totally different on each, I assume you could make a wiring harness if you have the pin diagrams and some extra time on your hands. I would be interested if anyone has tried this also.
EOC Rank: Crankypants
Welcome, Syd247.
Not at all. The HVAC unit, including the fan, is accessible behind the glovebox.
A thread-title search for keyword "instrument" returns this relevant thread, which is also stickied at the top of the Do-It-Yourself / Mods section:
Instrument / gauge cluster: bulb replacement / color change / LED conversion
> same for headlights
A thread-title search for keywords "headlight" or "HID" in the Do-It-Yourself / Mods section returns several relevant threads, including these:
http://www.elementownersclub.com/forums/showthread.php?t=105562
http://www.elementownersclub.com/forums/showthread.php?t=83945
http://www.elementownersclub.com/forums/showthread.php?t=61986
http://www.elementownersclub.com/forums/showthread.php?t=55359
Also, Alabaster Silver Metallic is a 2006–11 color. Satin Silver Metallic, perhaps? Finally, please add your location (Mesa, Az., yes?) to your profile. It can help others help you.
