as the title implies- i'm swapping the HU on a 2005 LX. i looked thru 18 pages of posts last night, so i've tried to answer my questions thru the forums history... but none of them touched on these exact questions.
so here goes:
first- on the attached pic... i've divined that the far left black plug (#1) is the sub woofer, the next white plug (#2) is for XM, next long black plug (#3) is the main hookup, the little green one is the aux. and the round hole on the far right (#5) is the antenna
am i correct?
second- if the above is correct, does anyone have the honda part number for the aux jack wire/connector? again, IF i'm correct in my assumptions- it should go into the green jack (#4) in the picture and terminate into a stereo headphone jack.
many thanks in advance for ANY help.
(the reason for all the assumptions is- the unit i'm taking out is a non-aux capable, single disc unit. and only has the antenna (#5) and main (#3) wires available. i'm hoping i can get a later model stereo, and simply not use the sub or XM and purchase the aux wire/jack. any guidance will be greatly appreciated. thanks)
so here goes:
am i correct?
