1 - 17 of 17 Posts
Thought some of you might find this useful...
2003 Honda Element Wiring Information
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|white |+ |ignition harness |
| STARTER|black/white |+ |ignition harness |
| IGNITION|black/yellow |+ |ignition harness |
| ACCESSORY|black/red |+ |ignition harness |
| SECOND ACCESSORY|white/red |+ |ignition harness |
| POWER LOCK|white/blue |- |gray plug above drivers kick|
| POWER UNLOCK|white/green |- |gray plug above drivers kick|
| LOCK MOTOR|yellow/black | |driver kick panel |
| UNLOCK MOTOR|yellow/green | |driver kick panel |
| DISARM DEFEAT|yellow | |passenger kick panel |
| PARKING LIGHTS +|red/black | |driver kick panel |
| PARKING LIGHTS -|blue | |factory alarm plug *1 |
| HEADLIGHTS|blue/red |- |factory alarm plug *1 |
| DOOR TRIGGER|*2 |- |factory alarm plug *1 |
| DOME SUPERVISION|comes on with unlock| | |
| TRUNK/HATCH PIN|red |- |factory alarm plug *1 |
| HOOD PIN|yellow/red |- |factory alarm plug *1 |
| TRNK/HTCH RELEASE|black/yellow |- |driver kick panel |
| FCTRY ALARM ARM| | | |
| FCTRY ALRM DISARM| | | |
| DISARM NO UNLOCK| | | |
| TACHOMETER|blue | |test connector *3 |
| SPEED SENSE|blue/white | |cruise control module *4 |
| BRAKE WIRE|white/black |+ |brake pedal switch |
| HORN TRIGGER|orange |- |steering column |
| WIPERS|blue (L), blu/yel(H)|- |steering column |
| LF WINDOW UP/DN|red/blk - red/yel |A |driver window switch |
| RF WINDOW UP/DN|blu/red - blu/wht |A |driver kick panel |
| LR WINDOW UP/DN|blu/blk - brown |A |driver kick panel |
| RR WINDOW UP/DN|blu/org - blu/yel |A |driver kick panel |
| SUN RF OPN/CLOSE|grn/yel - grn/blk |A |relays above driver kick |
| RADIO 12V|white/red |+ |radio |
| RADIO GROUND|black |+ |radio |
| RADIO SWITCH|yellow/red |+ |radio |
| RADIO ILLUMINATE|red/black |+ |radio |
| LF SPEAKER|grn/blk - lt green | |radio |
| RF SPEAKER|grn/yel - gry/red | |radio |
| LR SPEAKER|blu/wht - blu/blk | |radio |
| RR SPEAKER|pink - blu/yel | |radio |
AUX wiring on radio:
According to the service manual, the green one is refered to as connector 202-D. Six pins, starting fron the left with the key on top:
1= yellow, (AUX-DET)
2= blue, (AUX-GND)
3= brown, (AUX-Audio Right Channel)
4= green, (AUX-Audio common ground)
5= white, (AUX-Audio Left Channel)
6= lt green/red, (AUX SH GND)
You need to short wires 1 and 2 to activate the AUX port on the stock radio.
NOTES:
This vehicle has an immobilizer system that needs to be bypassed when adding remote start. Use DEI part number 555U.
*1 The factory alarm plug is a green plug to the left of the steering column.
*2 The drivers door trigger is green, and the passenger door trigger is lt. green/black. Use both and diode isolate each.
*3 The test connector is next to the battery.
*4 The cruise control module is to the left of the steering column.
Is this really for the element??
Last time I checked my E, I didn't have electric rear windows, or sunroof option :)
just kidding Emass, I was waiting for this so I could put in a remote starter. In the intructions it was talking of tach wires and other wires I would not know where to look for. I think there only a couple missing I will have to find out, but this is a good start...Thanks Emass
EMASS,
I am installing Infinity Reference speakers (components up front, coax in back [6.5"]). Following your wiring information below regarding the stock speaker wire colors, am I correct in believing that the first wire color noted for each speaker is the negative (-) lead, (eg. pink is the negative for the RR speaker)?
Additionally, is the stock system using crossovers to pass only mid/high frequencies to the doors or are they receiving the full signal? I just want to confirm that since I am intending on connecting the stock leads on the existing door speaker to the Infinity crossover and splitting thereafter to the new tweeter and door speaker.
I appreciate your help and all the information you have already provided this forum.
Thanks,
mprystauk
[quote:2625a67f36=" "]Thought some of you might find this useful...
2= blue, (AUX-GND)
NOTES:
*4 The cruise control module is to the left of the steering column.[/quote:2625a67f36]
I'm having some issues with my alarm install. it's a 2004 E without any factory security.
#1: For parking lights, I can use + red/black at the driver kick panel. I can't find this wire. Which harness should I find it on
#2: For door trigger, I found the green harness. But since I don't have any factory security, this harness is just dangling. Should I still tap into the wires there?
#3: For the door trigger, I think DEI is wrong for the passenger side. I found a gray/black wire, not a green/black. Should I go for gray/black?
Thanx everybody!
Jae
[quote:b34d39eef4="Rattlecage"]I dont know how useful this is, why is negative and postive not listed on the speaker wires, etc?[/quote:b34d39eef4]
Probably to keep the average joe from messin' with the factory wiring. If applicable, I would HIGHLY recommend that you not hack into the factory wiring, else you might void the electrical warranty. If you are putting in an aftermarket stereo, any reputable stereo house will sell you an adapter for about 10 bucks that plugs into your factory plug at one end, and has (clearly marked) wires at the other end. Likewise, there are adapters for the speaker connection as well so you don't have to hack that end. Well worth the investment if someday you ever sell your "E" and want to return everything to original factory condition. This is ESPECIALLY important if you are LEASING your vehicle! :shock:
LEGO
ressurecting a dead thread...
Sorry to ressurect a dead thread, but after searching, this thread seemed the most appropriate.
I have read about the 05's using shared wires for different purposes (in the trailer threads), does this affect these color codes? I've peeked under the dash and found a few, but haven't put my multimeter to it yet. I was an installer for years, so I'm comfortable with handling the wiring and the airbags, but this was prior to the new shared wiring - around 9 years ago.
After installing the alarm and stereo on my last vehicle (01 Silverado), this reminds me why I enjoyed working on Hondas, Toys and Nissans. Everything is clean and easy to identify under the dash. Also the components come apart and go back together as they should.
Thanks in advance.
2007 Honda Element
Alarm installed. PM me if you need help.
Jae
Hey Jae,
I was reading your comment recently as I was having the same problems in my girlfriend’s 07 Element. Below is what you posted:
”#1: For parking lights, I can use + red/black at the driver kick panel. I can't find this wire. Which harness should I find it on
#3: For the door trigger, I think DEI is wrong for the passenger side. I found a gray/black wire, not a green/black. Should I go for gray/black?”
Anyway, I can’t find #1 either, I don’t even know where the factory alarm plug is (my vehicle specific wiring sheet says door trigger is there), and finally for #3, my diagram also said gray/black instead of green/black. My question is, where can I find the factory alarm plug (if there is one, as this vehicle is equipped with a factory panic button on it’s key fob). I will try to find out all of this on my own tonight if you can’t get back to me right away.
Thx!
-Almeida
· Retired.
Hey Jae,
#3: For the door trigger, I think DEI is wrong for the passenger side. I6 found a gray/black wire, not a green/black. Should I go for gray/black?”
Thx!
-Almeida
He hasn't been on here since 2004. I don't think he will be getting back to you anytime soon.
2= blue, (AUX-GND)
NOTES:
[/QUOT
2= blue, (AUX-GND)
NOTES:
2= blue, (AUX-GND)
NOTES:
[/QUOT
2= blue, (AUX-GND)
NOTES:
please is there any chance you could get me a schematic for the keyless entry module? I am specifically looking for the key sensor wire at that module? Thank you what I’ve read you have great information.
1 - 17 of 17 Posts
