1 - 14 of 14 Posts
Since I tend to "over engineer" everything........this is an accomplishment in simplicity! Originally I was going to build a complete a console, with storage compartment etc, but I have other projects I need to get to and ALL I really needed was a better cup holder for my Venti Starbuck (stop every morning on the way to work).
Will finish a ver 1.1 with an additional section extending it to the rear edge of the seats eventually and then ver 1.2 will have a more polished/professional finish.
I was also going to raise the armrest but after taking everything apart I realized that part of the side airbag was blocking it. At least now I know why it's lower.
Nice job, simple yet very effective. Is that a cutting board type material ? Would love to see you do that complete console.
Thanks, it's made out of 1/4in plywood.
My plan is to complete the console after I get some airbrush projects done, which is on hold until spring cleaning is done. :)
Does the unit move at all or does it fit snug? :?
P.S. Might I steal your idea, instead of using those bolts with nuts, I would use equivalent sized spacers but epoxy it so the top surface of the cuphold has a clean look (no bolts or nuts sticking out).
Go for it! :)
I was originally going to extend the sides but I have other plans for later.
Going to put a OBD scanner just above the cup holder and below the edge of the shifter.
http://www.scangauge.com/products/scangaugeii/
Going to mount an inverter in the bottom....
http://www.amazon.com/dp/B004MDXS0U/ref=gl_it_dp_o_pC_nS_img?_encoding=UTF8&colid=FP0TPTM4GF4B&coliid=I34SH0FZ8PXONV&psc=1
Trying to think of a place where I can put my Keurig :)
The cup holder was made from scraps from another project and I was going to use spacers but they were like $5 each at Lowes and for a simple afternoon project didn't think it was worth it.........so went with the nuts and bolts.
Other project;
Paint was from another project, Grandson's helmet :)
It's not attached at this time but it fits pretty snug. If it moves around any I'm going to put a "sand/bean bag" on the shelf at the bottom.
Have fun and post pics of what you come up with.
Wondering what you think about having a simple backing behind the cup-holder area so that your subwoofer is protected in case of any accidental spills...
Discussion Starter · #7 ·
be a good idea and i was going to put a back on it, still might, but if I mount it to the dash I'll cut the wood to fit and put a thin piece of rubber between the cup holder and dash.
I'm thinking the back would muffle the sound and if/when I put a back on it I'll probably cut out part of it and put a screen over it.
Nice work I really like the simplicity of it. Is it just wedged in the space between the sub woofer and center console? then sand/bean bag will then keep it from tipping left and right?
Looking forward to your center console ideas. thanks for sharing.
on a side note.
I have heard that those air fresheners will eat through your paint. Even hanging from the mirror they drop chemicals that eat away paint on the dash.
Discussion Starter · #9 · (Edited)
on a side note.
Thanks for the heads up on the air freshener! I had a little one that was mounted on the vents that was made of plastic. I'll probably go back to those.
I haven't even used the cup holder yet, put it in and haven't gone anywhere yet. It fits pretty tight but if it's top heavy with coffee then I have industrial strength velcro I'm going to use. Since I plan on changing things up I don't want to drill or actually mount it just yet.
Update;
Just got back from a short drive and .............gotta anchor it, going to try the velcro first and see how that does.
Discussion Starter · #11 ·
Nice job!
I installed a cupholder in the same position, but mounted it to the subwoofer cover- link in my sig.
I like your cup holder install, very clean.
I've got a couple of changes for when I complete ver 1.1, hopefully this weekend
Discussion Starter · #12 ·
Over a year later! ver 1.03
Well! I finally made a few minor updates and although they are minor they make the cup holder much more functional.
-Raised the top so that it holds taller cups better.
-Bottom shelf is much longer so that it is supported by the existing console.
-Covered it with vinyl wrap
-Used industrial strength velcro between the bottom shelf and existing console.
Much more stable while easy to remove with no permanent mods to the car.
I know I'm a slacker on this but I did do a few other projects. Vents, Nerf Bar and painted several goalie helmets :)
thanks for the update.
and if your vehicle is a 2004, the color is Fiji Blue Pearl, which is not quite the same as Royal Blue Pearl.
Discussion Starter · #14 ·
thanks for the catch on the color :) Just goes to show the mind sees what it want's to see. Every time I read it, it read fiji to me. Had to read it three times before I saw it
1 - 14 of 14 Posts
