I have a 2006 automatic. When I'm cruising usually around 45mph, the front end will start vibrating until I let off the gas. I feel it more in the pedals than the steering wheel. I feel like its nothing to do with wheel bearings or suspension. Anybody have any clue?
Is it possible one of the wheel threw a weight?
A wheel weight wouldn't be affected by throttle input as the wheel is constantly rotating and would be felt even if he let off the throttle. Seems like the issue is more dependent on vibration dampening from the motor or drivetrain. Would also usually be felt in the steering if a wheel was off balance.
Only reason I ask is that on one of my VW's I lost a sticky weight, but it wasn't obvious until 50+ mph, then the steering wheel gave off vibration.
Check rear differential mounts. Three of them
