1 - 13 of 13 Posts
Hi
I was told there is a leak in my vtec spool valve and needed a gasket replacement for $200.
First day back I look and sure enough fresh oil on the bolts outside the valve and some spots outside. Over the next couple of days I routinely wipe it down with a new paper towel to check and all I get are some light brown oil smudges on the paper towel but no much otherwise. I have driven on local roads as well as highways. Oil in the engine is still fresh and clear. Is that normal?
Thank you.
Jon
PS for the time when I do have to change it, can it be done though the passenger side tire well? In all the videos people do it from top or bottom but I see lots of room through the passenger side tire well and was wondering what people thought.
The gasket itself lists for $6.16. Just a few 10 mm bolts to remove the spool assembly. Going in through the wheel well seems like it is making it more difficult than it needs to be.
I’m on the same page as fleetwood. New gasket somewhere between $5-$10. 3 bolts, on at something like 9ft lbs, although it will feel like 30-40 ft lbs taking it off. I went from top. Probably wisest to do on a cold engine. I think you’ll be done in 15 minutes.
one of these helps tremendously:
  • Like
Reactions: Jon_element
Thank you!
Lol:) Yes definitely cold. I did a check 30 minutes after a drive and in the summer it holds its heat. I have all the parts gasket, o ring and a new OEM spool. I was going to do gaskets, but I think I'll install the new spool.
Discussion Starter · #6 · (Edited)
Replaced the spool valve, and it needed a replacement since a mechanic at some point damaged the connectors and caulked it back on. Engine is running smoother with the new valve, but throwing a p2649 code. Should I reset the ECM and drive and see?
Discussion Starter · #7 ·
Pulled the ECM fuse for 5 minutes and reset the ECM:)
Discussion Starter · #9 ·
In case you need it, I just posted a screenshot for the P2649 service algorithm in this thread: Sputtering at 3000 RPMs even after new solenoid
Thank you! Engine is smooth on the test drive (highway and local) and the light has remained off after the reset. Done minimal driving cause I have not done the recommended oil change after the spool valve replacement. I had one done recently before the valve replacement and I am probably in the first thousand miles since. Is the recommended change because the gunk could clog the screen and cause an error code or is it recommended for some other reason?
I don’t see anywhere in that screenshot that I had posted that mentioned anything about an oil change for P2649. Are you mixing up your code with P2646?
Discussion Starter · #11 ·
I remember seeing someone post a Honda advisory recommending an oil change after the vtec spool gasket or valve replacement and was wondering if you knew?
Sorry, no help on that one. I would be unaware of any.
2004 Honda element Awd automatic
My leak was at first suspected to be the one you changed but it ended up being the actual oil pressure switch that is on the vtec solenoid itself. The oil switch had a leak on the actual place where the plastic meets the metal.
1 - 13 of 13 Posts
