1 - 11 of 11 Posts
:idea:
It would seem to me that the area just below the grill is very open and unprotected against rocks and other stuff kicked up by other vehicles. I bet that someone will come out with some kind of screen for that area to protect it. If something were to penetrate those radiators, it could result in either a a/c failure or overheating the engine due to loss of coolant. Let me know what you think about this????? :?:
I added a screen to my E to provide protection to the A/C evaporator. I removed the entire front end in order to install it but it only took 20 minutes to get it off and less than that to reinstall. I made a tool to remove the plastic clips from an old pair of tweezers. There are 18 clips and 4 bolts to remove and the entire front end comes off allowing access to install screening using duct tape. Not for the timid, but not difficult either. :wink: [/img]
This board doesn't host the images posted in messages. You need to upload to your own web space and then use the IMG button to embed the image URL. I think that GypsyTDA was offering to host images for people who don't have web space, so check with her if you need somewhere to post pics.
[quote:e5ffd4a5d3="utahrex"]I added a screen to my E to provide protection to the A/C evaporator. I removed the entire front end in order to install it but it only took 20 minutes to get it off and less than that to reinstall. I made a tool to remove the plastic clips from an old pair of tweezers. There are 18 clips and 4 bolts to remove and the entire front end comes off allowing access to install screening using duct tape. Not for the timid, but not difficult either. :wink: [/img][/quote:e5ffd4a5d3]
Would love to see a photo of your handywork if possible. 8)
1 - 11 of 11 Posts
