Ok hopefully this will not be a dupe. Typed it once but didn't see it appear in the forum.
Looking to install some warning lights(led) into the Element this weekend and I've got a couple questions. I've done a couple quick searches but nothing that I've found yet has helped.
1. Does the 2009 E have any pre-drilled pass thews? I looked on the drivers side last night, but didn't see anything obvious.
2. On the center console, is there enough room either below or on the opposite is of the hazard light switch to mount another switch?
3. For furture reference I might later on install more lights on the back side of the vehicle. Does the E have a channel leading to the back that I can run more cable through to reach the hatch area?
Thank you for your assistance/guidance
Steve
Steve
