Hi all,
After some unsuccessful searches, I unfortunately have to start a new thread about this.
My low washer fluid indicator came on yesterday, so I filled up the reservoir. I was able to put a bottle and a quarter in (how big is the reservoir??) last night. This morning, I then noticed that the indicator light was still on. I checked, and I could still see blue from the fluid in the reservoir. There was no longer any in the neck leading down though, and I'm pretty sure I had filled it to the top (could be wrong). I then backed up the car and checked for blue snow underneath, but didn't find any indication of a big leak.
Any ideas on how to reset this indicator, or should it happen on its own? I will check again for leaks, but if there isn't any, is there some sensor that could be faulty? Is this a common problem? With my older VW, leaks around the reservoir were a common issue. How big is the reservoir?
Your help is appreciated,
Thanks
Thanks
