I have a water leak that is causing pooling of water in the passenger foot well, both on top of and underneath the flooring/padding.
The issue happens when the vehicle is parked and is exposed to heavy rain. I have had the AC condenser line blown out and that wasn't the issue, so I am convinced it's water intrusion from rain. The water appears to be coming in behind my dash or from my heater box, I am unsure which without taking the dash apart.
The amount of water varies based on degree of rainfall, but this morning, I had somewhere between 15-20oz of water in my floorboard and underneath it.
It seems like the issue began after a windshield replacement, SafeLite checked the windshield and their seals around the glass were good to go. I'm unsure what their tech could have messed up that would have causes the issue if anything.
Any help would be outstanding.
The only help that can be given is for your to start pulling the dash off and interior pieces so you can run a water test yourself to find the leak
More than likely its due to the windshield install
