Yeah, water leaks on the bottom of my element too when im using the ac and my brother is an auto tech and said that it's normal so your probably ok.Noticed this while using the AC on full blast and hoping it's just the condenser. Anyone else experience this?
All cars do this when the AC is running. It takes moisture out of the air and it has to go somewhere.Noticed this while using the AC on full blast and hoping it's just the condenser. Anyone else experience this?
Nothing to worry about, perfectly normal. Start to worry if the liquid has color to it like green or blue...that would be coolant and you would want to find out where it was coming from.Noticed this while using the AC on full blast and hoping it's just the condenser. Anyone else experience this?
Mine is NOT coming out - I'm also getting a mildewy smell after running AC - I'm obviously not draining humidity properly. Can anyone point me in the direction of finding and clearing my drain?Worry when the water doesn't come out.![]()
Change your Cabin Filter.Mine is NOT coming out - I'm also getting a mildewy smell after running AC - I'm obviously not draining humidity properly. Can anyone point me in the direction of finding and clearing my drain?
Parked the car, went inside for 5 minutes:No big deal, it doesn't have to do with what fan speed you use, just moisture content of the air. On REALLY humid days, I can have a gallon of water under the car in less than a half hour.
Does anyone know exactly what those are? I am on my second E, and the first time I never noticed this, but in the new one, I have seen it a few times. Is it when you turn on defrost?All that water on the ground is good—it's water removed from the air in your car.
Didn't you read above? AC, condensation, humidity, etc.Does anyone know exactly what those are? I am on my second E, and the first time I never noticed this, but in the new one, I have seen it a few times. Is it when you turn on defrost?
