If you have a jack, remove the rear right tire and locate nuts and bolts holding the knuckle and control arm. Try using a half inch ratchet to tighten bolts. If you are able to turn the bolts at all using a ratchet then chances are they are just lose from a previous repair done wrong. You should be safe using brute force to re-tighten the lose nut or bolt if you're not a body builder. A torque wrench would be preferred but remember to go 10lbs over on torque spec to allot for rust and the toll weather has had on suspension parts.
Hearing a thumping sound coming from the back right side of my newer 03 when I go over bumps. Any ideas?
EXACT same thing happened to me and my 2006! Shocks went bad + the sabilizer, AND.... the nosie is still there. I traded it in yesterday and am sporting a 2009 Ford Ranger now.. I had just about enough of the E truck .. that I loved dearly ... but it never loved me or my pocket ;-)
