My car has started making clunking noises in the front end when driving over washboard roads. I did a quick search and found out that at 50,000 miles, it's not unusual for the E to need front struts and this is the classic noise they make when they go bad.
I stopped by the Honda dealer on lunch break and after a $750 quote, I quickly left. I've been calling around town to shops that have done work for me in the past and found one that will do the job for $190 plus parts. While I'm still waiting for other shops to get back to me, this seems reasonable. My only question is what struts? Obviously I could buy the Honda ones but they will be too expensive through the garage and they won't let me supply them myself. The only aftermarket strut I can find that is a OEM replacement is by KYB. Is this the company that supplies Honda their front shocks? Is there anybody else making an aftermarket front strut that might be better? I don't want to lower the car. I just want to make it stop going clunk.
As a side question, do I need to replace the strut mount or strut bearings? I found this paragraph on drivewire.com that I thought was interesting. Anybody care to comment?
Who can help me strut my stuff?The Honda strut mount is located on the top of the Honda strut assembly and is used to provide a pivot point and mounting location for the strut. The strut mount is only used on cars equipped with Mac Pherson type struts, and are typically only found on smaller compact cars. The Honda strut mount is typically made of rubber and has a strut bearing in the center that allows the Honda strut to turn right to left with the steering. The Honda strut mounts should always be replaced went replacing the strut assembly. An indication that the strut mount has failed is you would hear a knocking noise while going over bumps, the other way you may notice a Honda strut bearing going bad is that the steering seems a bit hard when turning the wheel. If you need to replace the strut mount or Honda strut bearing you will need to remove the strut assembly from the car. Be careful! The Honda strut mount and bearing actually holds the spring under hundreds of pounds of pressure, and if you remove the gland nut holding the strut mount to the strut assembly without using a spring compressor you will cause yourself great harm. Best bet is to remove the Honda strut assembly and take it to a Honda professional and let them replace the strut mounts. You will need to realign the Honda suspension after changing the strut mounts.
