My 2003 E has seen no service aside from oil changes, is there something I should DEFINITELY have done at this point (75,000 miles)?????/
I'll suggest:
rear differential fluid change
transmission fluid change
transmission filter replacement
throttle body clean
drive belt replacement
air filter replacement
cabin filter replacement
many wouldn't yet, but I would replace the spark plugs
Other items to check:
drive belt tensioner pulley
brake pad wear and slider lubrication
Keep your E happy :-D
i just hit 71k,,,i just did the drive belt,,tranny fluid change,radiator coolant flush,,rear diff fluid change,,cabin air filter and engine air filter change,my brakes pads are still good but i did regrease the slider pins..and i changed the 4 spark plugs,,,i did everything myself with the awsome help of this forum,,i do suggest using all honda parts and fluid..and with the money i saved i used to buy an eoc sticker ( lol)....good luck...also i did the power steering fluid change
brake service: clean & lube and fluid flush (well overdue...the fluid has been in there about 7years, fluid replacement is recomended every 3!)
trans service: fluid & filter
diff fluid
Coolant fluid change
engine air & cabin filters (both well overdue)
