1 - 7 of 7 Posts
I have a 2003 Honda Element! I bought it 3 years ago. It's been a Great car. This summer I have putting up with over Heatting. I have put some $ into it trying to fix. Well I just found out I have a Cracked Head Gasket. Which is gonna cost me alot to fix. Should I fix it? (Is it worth it?) Or let it go? Sell as is?
2007 Element EX AWD AT (two!)
How many miles? What condition is it in otherwise? Buy an OEM service manual, a cylinder head gasket kit, and do it yourself.
Mileage 193504 .....fair condition. I just had alot of work done. So I hear you man. So I shall check into that. Thanks alot!
Another option is a used engine. probably a good idea to have your overheating issues solved also.
I just paid $2500 to have head gasket replaced. They also replaced thermostat, timing chain, milled head, valve adjustment, etc. I figure if I get another year out of it, I have broken even. 194,000 miles. Runs great again
Do a pressure check on your radiator. I had the same issue on my 03. I changed everything and it was no fix. It turned out a crack in the radiator top plastic. No more issues. If you cracked a head, I would get replace engmine or rebuild. Good thing about rebuilding, you can mod the hell out of it.
1 - 7 of 7 Posts
