I need to install a amateur radio and need 12 power but only when the ignition is on.
As the radio draws heavy amp. We use what's called a 'A Relay'.
When the ignition comes on, it will energize the relay which has big wire connection to the battery.
When ignition is off, the relay drops out and the radio goes off.
So which wire should I tap into to energize the relay.
please and thank you
Feel free to email direct [email protected]
Feel free to look at my weather and webcams at:
http://hhweather.webhop.org
