1 - 14 of 14 Posts
Finished my window coverings today. I used 1 25’ roll of reflectix from HD with nylon material spray glued on both sides. I chose grey for the interior side and black for the outer. I don’t like the way you can see the reflectix when it’s pressed Up against the window so I spray painted it flat black before I glued on the black nylon material just to get maximum stealthiness.😬
205070
205071
205072
205073
205074
205075
2008 silver/grey LX
Finished my window coverings today. I used 1 25’ roll of reflectix from HD with vinyl material spray glued on both sides. I chose grey for the interior side and black for the outer. I don’t like the way you can see the reflectix when it’s pressed Up against the window so I spray painted it flat black before I glued on the black vinyl material just to get maximum stealthiness.😬 View attachment 205070 View attachment 205071 View attachment 205072 View attachment 205073 View attachment 205074 View attachment 205075
Looks awesome!!
2007 Element EX, 250,000+ miles and still rolling
I'm looking to do this as well, but have a question - does painting the outside black/using black vinyl help to absorb more heat? Have you noticed any difference?
hey @jonersboners I haven’t tested it out in full sun yet. I can’t imagine it will make a huge difference. My motivation for paint/nylon was appearance and durability. My windows are completely blacked out from the outside instead of seeing the foil looking reflectix. I chose nylon since it should clean up a little better than regular fabric. (Im just now realizing in my original post I said vinyl instead of nylon😬)
205084
Hey, thanks for answering! It looks really awesome, and makes me want to just do it already.
Very nicely done! I made some with the same thinking, black out & gray inside. I like your idea of spraying them. I spent soooo many hours sewing mine together. A cool tip I learned was the back of the front seats have zippers & there is a huge hollow area inside them. I store all my window coverings in there when they aren't being used.
Very nice and detailed looking compared to the unlined ones I've made for mine. As far as camping, mine don't fit quite that precisely, and several times if it's cooler outside at night, the windows will fog up from the breath condensation and temperature difference. But the privacy aspect is worth it.
Looks really neat and well-finished. Could you say more please about the nylon material and the adhesive you used? How you attach them to the windows?
Those look great, and I really like the way you built your bed to cover the front seat as well, I am a NEW owner and have been watching all the videos on how to build a bed, but I thought it would make more sense to do it the way you’ve done it. Unfortunately I hadn’t seen any one else doing it so I was going to design my own system, but now I’ve seen yours and the template is already created, thank you.
Any chance you created a good set of window patterns that you have considered selling? It would certainly save a ton of tedious labor for the rest of us and put a little Ching in your pocket to boot.
2010 Honda Element
i’ve never been able to get my front seats down that far... (2010, back seats have been out forever)
2010 Honda Element EX alabaster
that's why i put a dometic rv fan vent on top! ...with a cover so you can't tell if it's open or if it rains nothing gets in..etc
1 - 14 of 14 Posts
