1 - 10 of 10 Posts
07 2wd 5-speedauto
After 13 yrs of ownership, I finally added some footwell lighting.
Wired up 2 194 bulb sockets with LED's and zip tied them under the dash as close to the door as possible. Lights up the ground nicely when the door is open, this way no more stepping in dog sh^t at night.:rolleyes: They come on only when a door is open, independent of the dome light switch. There is a wire harness connector behind the glove box with both the fused power and the ground signal from the doors that I tapped into with scotch locks. Install was pretty easy.
07 2wd 5-speedauto
07 2wd 5-speedauto
Discussion Starter #9
Love this mod, which I knew more about wiring and such.
Its easy to add lights, only 2 wires. Or go to a stereo/alarm guy, they would know exactly what to do. Install was 15 minutes.
07 2wd 5-speedauto
Discussion Starter #10
This is the connecter to get the power and ground feeds from. It's a light blue connector behind the glove box mounted to the right side. This is for a 2007, not sure if other years are the same.
  • Like
Reactions: AWD
1 - 10 of 10 Posts
