Honda Element Owners Club Forum
Go Back   Honda Element Owners Club Forum > Accessories, Care and Mods > Do-It-Yourself / Mods
Notices
ElementOwnersClub.com is the premier Honda Element forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Reply
Thread Tools Display Modes
Old 05-21-2006, 09:02 PM   #1
clex2
EOC Rank: Helium
2004 4WD EXS MT
Satin Silver Metallic (SSM)
clex2's Avatar
DIY: Glove box light
Several threads talked about the lack of a glove box light. So far, none of the solutions offered have been worth considering, so I tried to tackle this problem myself. I do a lot of work on my BMW's, and I had some spare parts lying around which happen to be perfect for this project.
The first two pictures are the parts with part #'s. They can be had at any BMW dealership or BMW parts vendor. Just supply them with the part numbers. The parts are relatively cheap, even though they are BMW. I think $20 would cover it, maybe less. A regular incadescent bulb will be supplied with the BMW lamp, but I used a LED replacement to match the rest of the LED bulbs in my Element.
After getting the parts, find out a suitable supply of power. I used a add-a-circuit to the #18 fuse box location with ground being the common ground on the way right of the glove box (bolt).
Undo the two glove box stops on the sides (snap out)
Remove the passenger side dash board garnish right above the glove box. There are 2 fillister head screws to the sides of the metal U latch that you need to access from up and behind the glove box. Then push from below/pull from the top straight up and it will come loose. Two more screws way to the sides hld the metal rail with the metal U latch. U need to take this off also.
Measure the openeing of the BMW light (roughly 6.9 cm x 2.9 cm) and cut a hole in the location shown. You can drill a bunch of small holes and use an exacto knife to cut the plastic. ***DO NOT make the notch that you see in the picture. That was my mistake, but fortunately, the metal rail was cut properly and the light snaps into place***
The metal rail with the U latch needs to be cut. Put it back into position and hold it there and using the hole you just cut in the plastic, take a marker and mark what needs to be cut. A dremel cutting wheel makes this easy. Paint the bare edges with black paint to prevent rust.
Now do the same for the glove box light switch. The switch itself needs to be modified by cutting off the plastic around the pins. The pins need to be bent upwards slightly. These modifications are done to clear the metal bar just behind the switch location.
Reassemble everything, making sure that the light and switch fit snugly.
Wire it up, making sure to cover the female switch pins with shrink tubing or I guess a generous helping of electrical tape. They just can't make metal to metal contact with each other or worse, the metal frame sitting just behind (see short circuit, blown fuse).
__________________
'04 SSM EX-S 5-spd*fogs*side steps*air deflector*bumper trim*splash guards*wheel locks*locking gas cap*cd changer*Pilot leather steering wheel w/radio controls*rubber mats*cargo tray & cover*clear side markers*Interior LEDs*Sirius*lLower grill guard,*9" Panasonic DVD w/ 6" front pass. monitor*pass. power door lock switch*Storage Armrest*Alarm*GPS*Glove box light*Auto-Dim/Temp/UV/Compass mirror*Red Valve Cover*Meter/Center/Switch Panel Trim*Roof Rack*Made in USA Emblem*Flip Key*'09 FIT knob*SG II
clex2 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-21-2006, 09:04 PM   #2
clex2
EOC Rank: Helium
2004 4WD EXS MT
clex2's Avatar
More pics:
__________________
Old 05-21-2006, 09:07 PM   #3
lwclancers
Chief Has Been Element Owner
2010 4WD EX 5AT
Citrus Fire Metallic (CFM)
lwclancers's Avatar
Send a message via ICQ to lwclancers Send a message via AIM to lwclancers
Nice work!
Same kind of ingenuity I did for my passanger dash lights :D
__________________
2010 CFMEX4WDAuto
2004 NBPEX4WDAuto - RIP 8/13/05
2005 Accord Hybrid w/ Nav - Desert Sand Metallic
lwclancers is offline   Reply With Quote
Old 05-22-2006, 10:36 AM   #4
ramblerdan
Moderator
2004 4WD EXS MT
Fiji Blue Pearl (FBP)
ramblerdan's Avatar
Looks good. That plunger switch is just the ticket.
ramblerdan is offline   Reply With Quote
Old 05-22-2006, 11:01 AM   #5
outpost4
EOC Rank: Iron
2004 4WD EXS AT
Sunset Orange Pearl (SOP)
outpost4's Avatar
Nice work and an even nicer write-up. Thanks.
Now all I've got to do is find a BMW dealership. There is one in Rochester, Minnesota, which is about 70 miles from me. I go there occasionally for business.
__________________
the car stereo install in my Element: thread and pictures
my other ride:
This one I have actually riden, often, and have enjoyed seeing it roar by my house. :) Friends of the 261
outpost4 is offline   Reply With Quote
Old 05-22-2006, 11:46 AM   #6
lwclancers
2010 4WD EX 5AT
lwclancers's Avatar
or you could just use the internet :D
__________________
2010 CFMEX4WDAuto
Old 05-22-2006, 02:25 PM   #7
outpost4
EOC Rank: Iron
2004 4WD EXS AT
outpost4's Avatar
.....D'oh!
__________________
my other ride:
Old 05-22-2006, 04:23 PM   #8
aquilles10
EOC Rank: Oxygen
2006 2WD EX-P AT
Tango Red Pearl (TRP)
aquilles10's Avatar
Send a message via AIM to aquilles10 Send a message via Yahoo to aquilles10
Nice install! That is ingenious. I love the Element, but I wish that Honda didn't skimp on certain things, like power door lock switch for the passenger, and this a glove box light.
A good place for Bimmer parts online is : http://www.pacificbmw.com
Back when I had my 3-series, I would always find that Pacific BMW had the best prices for Bimmer parts. They ship to anywhere in the U.S. and a big part of their parts department business is internet/mail orders.
__________________
'06 Tango Red Pearl EX-P: Honda Pilot Leather Steering Wheel, SC Leather Shifter, Polk db650 front & rear, Grille Guy lower grill, Bracketron iPhone mount, Superbright LED's all around
aquilles10 is offline   Reply With Quote
Old 05-22-2006, 05:04 PM   #9
clex2
EOC Rank: Helium
2004 4WD EXS MT
clex2's Avatar
I buy quite a bit of BMW parts, and although Pacific has some of the best prices, their customer service is really poor. You can never get ahold of anyone in the parts dept and good luck getting them to answer your emails. For those reasons alone, I don't do business with them.
__________________
Old 05-22-2006, 05:55 PM   #10
tessa
EOC Rank: Oxygen
2006 2WD EX-P MT
tessa's Avatar
This is a fabulous install and write-up. Thanks for taking the time to share it.
My glove box light required about 30 seconds to install. :cool:
http://www.sylvania.com/ConsumerProd...s/Dotitlights/
Works great and the red matches my TRP. I know tango has the matchng one for her Tangerine, also.
Tess
tessa is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Aftermarket Fog Light, OEM switch wiring. Bob Walters Do-It-Yourself / Mods 24 06-18-2010 03:53 AM
Anyone install a glove box light? daroy Interior 23 12-03-2006 10:42 PM
Routing an IPOD adaptor from the stereo to the glove box. cloud9respect Mobile Electronics 4 09-01-2005 11:09 AM
Speed sensor behind glove box Gremlin Mobile Electronics 4 11-23-2004 02:12 PM
buzzing(behind glove box) followed by engine light elementalist Ask The Dealer 0 09-09-2003 10:14 PM
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
