Apparently a surprising number of EOC members are hams (you know who you are!). Clearly, we have something in common about the attraction of a true utility/activity vehicle that doesn't come with assumptions of what your life's "activity" is, and is moderately-priced. My first thoughts on meeting the E were "finally, someplace to put radios" and "easy to clean after a messy public service event".
I'd like to bounce around a few ideas and solutions (and hints and kinks) around ham radio-related applications with the E.
I'm a bit of a neat-nik with my mobile installs (although you'd never know that from my "classic" shack). I don't like exposed cables running everywhere, and I will drill interior panels if it hides wires. Current thought is to put control heads on a stalk in front of the subwoofer and hide the radio bodies (sounds morbid!) in the dash behind the stereo or under the passenger seat. I've also thought about putting something in the overhead console - if not a whole transceiver, maybe the microphones?
I have three transceivers (for six bands), two PDAs and one Doppler RDF controller that need to go on the control panel. One PDA is my APRS station, and the other is a front-end for a "black box" PC-controlled receiver (Icom PCR-1000). That's a lot of wires.
Thoughts about power? Fusing? Noise? A prior attempt in another vehicle at running power leads directly to the battery for all this met with beaucoup alternator noise, eventually solved by attaching the negative lead to a rear seat belt anchor!
Also... antennas? I prefer one antenna per band, but have been OK with dual 2m/70cm designs - which only "saves" but one antenna in my case. The last vehicle I had (Ford Escape), I fabricated crossbars which fit in the roof-rack attachment points, and used 1/2-wave antennas where I could. That worked well, and I plan the same with the E.
However - any thoughts about getting the coax inside without going crazy with the drill? I was thinking the plastic roof trim will do a great job of hiding entry points, at least.
