Stripped Oil Pan Drain Plug
9.8K views 35 replies 14 participants last post by  Sal R
After seeing the stripped plug, my first thought would be to first run the same size tap through the pan to try to clean the existing threads up, and use a stock size drain plug. If that doesn't work, escalate to to tapping the next size, and and a larger thread size plug if possible, and if that doesn't work, drop the pan.
