161 - 167 of 167 Posts
This morning, I unlocked my e from thirty feet away with my eight year old remote. Opened door and found green key symbol flashing indicating "immobilizer" system activated. I have searched for similar problem and found none. I have looked in owner's manual and my trusty shop manual. Since my key is no where near the ignition switch, let alone inserted, I am baffened at what is going on!!
This situation has been going on for over two months and happens only once in seven days. This morning at 7: 45 am , last monday morning at 7:45 am. Every week, it happens once at 7:45 am , usually on monday.
With the green key symbol flashing, I can put in my key and turn to start. Only other light that comes on is a solid Check engine lite. When I try to start the car, it cranks over perfectly but will not fire. Clearly gas is off as per immobilizer function. It is not an unlock/alarm malfunction as that system prevents starter from functioning.
If I remove key from switch, check engine light flashes very rapidly and green key lite still flashes. I have been disconnecting battery, rather than have what ever is going on continue.
I can actually start car with three or more seperate attempts to start using foot on throttle. When engine starts, it sounds just fine but I have no gage lights or gage readings. No tac rpm showing. I have a dim parking brake light on even if I release parking brake. Gage cluster transmission indicator only lights up P and N, other positions do not lite when shifter is moved. I have driven car in this condition around block etc and brought it back home. After ten to fifteen min with engine running, something "wakes up" and all systems are perfect for the next seven to eight days.:|
At this moment car is just fine as everything "woke Up".
I would like to avoid a "wallet flush" on this one and want to be as informed as possible before I darken the dealer's door.
The immobilizer being activated from afar with no key near by is really strange. Systems "waking up" indicates Multiplex problems. ONCE A WEEK!
As problems are electronic, my Scan gage II says no codes found.
I have tried to be as concise as possible. Love my toaster and would greatly appreciate any input. :?
My key light came on and the car would not start. Took it to an electrical shop and they found a loose wire behind the fusebox. 525 to fix and no problems now. Three hrs to find the problem.
So I have a o3 honda element the key kept getting stuck and sometimes wouldn't turn I would then jam the key in and out keeping pressure forward then it would turn over .after some time it stopped letting me turn it at all I was stranded over 100 miles from home so I drilled out the ignition but I drilled out the plastic ring that went around the switch now car won't start at all how do I bypass the security feature I have the key and ignition is drilled out how can I make it start
This should be a recall problem my Honda does all that I fix it by hitting the dash hard like 3 times and the other day I hit the railroad tracks my dash lights came on to where I can actually see them but it only lasted till I shut the car off
It turned out to be the key. Use your spare key for awhile.
2006, Honda Element. The car doesn't start. The blinking green key comes on and doesn't go off, I checked the under-hood fuse box. #6 ECU 15 amp fuse was bad. Replacement fixed the issue. Thank you all for your time and post. This all helped me to diagnose the issue. I truly appreciate this.
