I decided to switch out a bunch or my bulbs for LEDs, but the signals and stop lamps are giving me issues. I bought a few bulbs first, just to test fit & brightness. I don't mind the highspeed flash while I am just testing so I am NOT going to get the load equalizer thingies until I am satisfied that the bulbs look as good, or better than the originals. Please do NOT inject negative opinions here regarding what looks good or not, or is legal or not. I'm not looking for a thread hijack.
I am working on the front signals, back signals, side markers, and brake lights. Please keep in mind I have the "Side Marker into Side Signal Mod" as well. Also, I am only testing on one side of the car, to keep it simple.
I bought:
Front Signal (7443):
SMT Tower VI 68LED -7443 (shown V on the site, not VI)
Rear Signal (7440):
SMT Tower VI 60LED -7440 (shown V on the site, not VI)
(same image for both on the site, I know)
Side Marker (168/194):
SMT Tower III 25LED
(note: I had to modify the plastic base to fit, this is not a plug&play, electronics untouched)
Brakes (7443):
SMT Tower 120LED -7443
The Weirdness:
It seems like all the LED bulbs work individually, but when I put them all in together, some won't light, some light at weird times, and some light partially.
Setup #1:
LED Brakes in, working as expected.
LED Rear Signal in, working as expected.
LED Side Marker in, working as expected.
Incan Front Signal in, working as expected.
However, as soon as I switch out that last Incan:
LED Rear Signal in, won't light.
LED Side Marker in, partially lit.
LED Front Signal in, working as expected.
Setup #2:
Incan Rear Signal in, working as expected.
LED Front Signal in, won't light.
I thought MAYBE I mixed up the 7440 & 7443 signals, since they were poorly labeled, so I tried switching them, and got similar results to above, but rear signals also started going on when brakes would, and not when signals should.
Help!
Suggestions?
Any way to double check my 7440 vs. 7443? Unlike incand bulbs, they both fit snug in both sockets.
I bought:
Rear Signal (7440):
SMT Tower III 25LED
Brakes (7443):
The Weirdness:
Setup #1:
Setup #2:
Help!
Suggestions?
