My 93 MR2 Turbo
6.4K views 7 replies 4 participants last post by  blue-sun
#1 ·
1993 MR2 Super Red Sunroof Model
started life as a NA and I had a JDM turbo motor put in.
Mods list:
CT20B Turbo from JDM Gen III Motor
OEM Turbo 93 Gauge Cluster (original “mileage” piece swapped out – 100% accurate mileage on chasis)
OEM Turbo Rear Firewall Carpet
OEM Turbo Fog lights
OEM Turbo Fog light switch
OEM Turbo Fog light relay
OEM Turbo Chromed X-brace
OEM Turbo Chromed “Cold Pipe”
OEM Turbo Polished “Hot Pipe”
OEM Turbo Powder coated red valve cover (with silver TOYOTA)
OEM Turbo Trunk Badging
OEM Floormats
OEM 94-95 Tail Lights
OEM JDM Clear Corner with amber bulbs
OEM JDM Side Marker Eliminator (being painted currently)
5Zigen FN01R-C Hyper Silver wheels, 17 inch (front: 17 x 7 5-114.3, +42 offset
rear: 17 x 8 5-114.3, +35 offset )
Yokohama AVS ES100 Tires
SPEC Stage 3 Clutch
Resurfaced Flywheel
Custom 3inch Downpipe
2.5 Inch TKO Exhaust
Red Turbohoses.com hose kit
T-Clamps for all hoses
Yellow Lamin-X Fog Light film
Independently wired fog lights to battery
Color matched door trim and bottom edge
Autovation Aluminum Pedals
Redline Red stiched shifter boot
Panasonic MP3 Radio
Rockford Fosgate front speakers
SPI Series Boost Gauge mounted on sheet of carbon fiber above radio
(soon to be installed Autometer CF Ultralite Water Temp and Oil Press Gauges)
TRD Wires
TRD Short Shifter
ARC Intercooler
ARC Blow Off Valve
Blitz Intake
Twos R Us Manual Boost Controller
Twos R Us Engine Prop Rod
Twos R Us valve cover bolts
Twos R Us rear end links
Twos R Us front end links
Polished Aluminum Engine Cover Shroud
Dual SPAL Puller fans
“Kikosaurus” Polyurethane front and rear motor mount inserts
Speed Source Shifter Base Bushing kit
Speed Source Shifter linkage kit
“TRD” Chromed Oil Cap
Tokico 5 Way Adjustable Struts
H & R lowering springs
Sylvania Silverstar Replacement Headlight Bulbs
Removed Cruise Control Modulator and hardware
Suspension Techniques Front and Rear Sway Bars
Recent Pics:
#3 ·
BAD1994ZR1 said:
Nice car.
RAY
thansk!
it's definately a keeper after all the $ and time I put into her.
She's almost near completion. Last major thing (which won't happen for a while) is a paint job and some bodywork.
If/when I get a E it'll replace my current DD - 91 Integra.
#4 ·
Well,
My friends shop fixed some issues that my car had and did some mild tuning on her via a dyno and SAFC.
255 WHP and 244 FT/Lbs of torque @ 17 PSI.
All I can say is that she's a BEAST right now and I'm loving every second of it.
I'll post the dyno graph later when I get an electronic version of it.
#5 ·
blue-sun, what did you use to detail the red integra that is linked in your sig? I have a 93 accord that has a nice paint job, it doens't have hardly any scratches and no rust, but the paint just looks a little dull. What did you do to bring the integra back to life?
#7 ·
Well, I used some pretty aggressive stuff that really shouldn't be used by amatuers (read: not responsible is you mess up!)
I used a Porter Cable 7424 Dual Action Buffer
A wool Pad
Meguiars Diamond Cut
I did that 2 times on the entire car, then followed it up with:
Meguiars Red cutting pad
Meguiars Dual Action Cleaner & Polish
Then I topped it with Meguiars NXT Tech Wax
Can you tell I like the Meguiars pro stuff? LOL
head over to www.autopia.org for all your detailing ?'s
