Trying to locate the correct TPS (throttle position sensor) 2008 Element
2.7K views 3 replies 2 participants last post by  07lmnt
#1 ·
My partner's 2008 Element simultaneously showed check engine, VSA !, loss of cruise control and began bucking while accelerating at certain throttle settings. Searches of this site would leave me to believe the cause may well be a defective TPS. I understand that Honda designed their throttle body to have a non removable TPS but have viewed several Youtubes showing how easily the old one can be removed, a new one installed and how to calibrate the new one. I see several aftermarkets TPSs listed for 2003-2005 Elements but none for the 2008. Could one of you more savy folks direct me to an appropriate unit via a link. I'd really hate to have to put in a new $$$$$ throttle body for want of a mush less expensive sensor.
Thanks for any informed replies.
Hugh
#4 ·
Actually has 2 internal sensors, one increases voltage, other decreases voltage as the drive motor rotates the throttle shaft.
Sensors are not serviced separately, only complete TB. Wires and connections have to be in tip top shape or codes can set. Extremely finicky due to the possibilities of unintended acceleration.
The throttle pedal has 2 sensors that can give the same problems as the TB, so you need to scan for codes to start any diagnosis.
