I'm posting up a follow-up to my installation since it took me a long time to go through the 22 pages, at the time, of information, a few times to ensure I was doing everything correctly. Hopefully this will help others and make it easier for them. I did this on a 2004 Honda Element.
Here's what I ordered.
1) Tonsiki 12/24V Dual LED USB 4.2A Charger Power Outlet Adapter and Cigarette Lighter Socket for Motorcycle Car Boat Marine Carvan (Green) $15.99
https://www.amazon.com/gp/product/B071NRFX8N/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
2) 14 GAUGE WIRE ENNIS ELECTRONICS 100 FT RED 100 FT BLACK PRIMARY REMOTE HOOK UP AWG COPPER CLAD $21.95
https://www.amazon.com/gp/product/B06XCTWPMM/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
3) 270 PCS Heat Shrink Wire Connector Kit Electrical Insulated Crimp Marine Automotive Terminals Set $29.99
https://www.amazon.com/gp/product/B01GXQMP66/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
4) BUSS HHH 30 Amp ATM Add-A-Fuse $11.95
https://www.amazon.com/gp/product/B000GKEXK2/ref=oh_aui_detailpage_o01_s02?ie=UTF8&psc=1
5) Tonsiki 5Pcs 50 Size Large Cobalt HSS Step Titanium Cone Drill Hole Cutter Bit Set Tool for Plastic, Aluminum, Copper and Stainless Steel $20.99
https://www.amazon.com/gp/product/B01DZNIK6Y/ref=od_aui_detailpages02?ie=UTF8&psc=1
6) Lockitt POSI-TAP Assortment pack wire connectors 10-22 awg $9.16
https://www.amazon.com/gp/product/B00CMC5DII/ref=oh_aui_detailpage_o09_s00?ie=UTF8&psc=1
Total: $110.03, Obviously it can be done for a lot cheaper, but this is just a reference for others if they don't want to look for their own parts.
So the easiest place for me to install a second power outlet was on the center console because it's not as difficult to run the cable compared to placing it by the handbrake.
1) The center console can be removed by pulling on the bottom right corner until it pops out.
2) From there, you can start pulling it from around to get the rest to pop out.
3) You'll have to disconnect the cables for the HVAC and the Emergency light on the back of the center console before you can pull it all the way out.
4) Then you'll have to put the car in neutral in order to remove the center console.
5) Using the Step Titanium Cone Drill Hole Cutter Bit with a drill, I slowly drilled into the center console, continually checking to ensure the power outlet fit and also that I didn't drill too big of a hole.
6) This pic shows you the power outlet installed, with the circular piece that tightens it onto the back of the center console. It comes with 4 connectors so all I had to do was crimp it down to the red/black cables that I purchased. On the back of the power outlet, it shows which one is positive and negative so you won't have to guess. You can also see in the pic, where the center console clips are.
7) Feed the red/black cables through the center and down towards your fuse box.
8) I forgot to take a picture of where I grounded the black cable, but you can attach it to any bolt that is touching metal. I crimped a connector from the kit that I bought onto the other end of the black cable so that I could attach it to a bolt.
9) Crimp the other end of your red cable to the Add-A-Fuse. Depending on your power preference, I pulled fuse 18 from the fuse box, and inserted the Add-A-Fuse with 2, 15 amp fuses attached to it.
Note:
Fuse 2, 15 Amps - Rear accessory power socket, Power Always On
Fuse 3, 15 Amps - Daytime running lights control unit (Canada), Power Always On
Fuse 18, 15 Amps - Front power socket, rear power socket relay, Power On with Key
Reference:
http://www.skidmore.edu/~pdwyer/e/udfrb.htm
The power outlet lights up blue at night.
For the Dual USB Installation, I placed it by the handbrake, the rationale being that both the driver and passenger could use it, and rear passengers as well, and whatever is being charged could be placed in the cup holder.
Here's the underside of the cup holder, if you're having difficulty removing it, you can see where it needs to be removed.
1) As mentioned by a previous user, remove the subwoofer to give you more access in feeding the red power cable from the handbrake area to the center console area. It's attached by 4, 10mm bolts, 2 on each side as shown in the picture below.
2) You'll also have to disconnect this cable that's attached to the subwoofer.
3) Here's the underside of the cup holder, showing where I had to drill, using the same step cone drill bit.
4) Attach the red/black cables, crimped down to the connectors that's included, to the dual usb. Here's where I connected the black cable to a ground. And as suggested by a previous user, you can use a hanger to help in feeding it through under the plastic floor board. I bent a hanger into one long piece and folded one end to help secure the cable. I also used a crowbar to help pull up the plastic floor board so that I could feed it through easier.
5) As recommended by ramblerdan, I used POSI-TAP, to utilize the power outlet's power/red cable as shown below.
