Well, I've done this myself and it's not that complicated if you're technical/mechanically oriented. Here's the stuff you'll need:
Impact wrench and air compressor (trust me, you'll want one)
1 Set of deep metric impact sockets
Large C clamp
A packet or 2 of that No-Squeal brake pad stuff (if it didn't come with your pads)
Hammer/small bar to pry with
Jack & stands
1 block of wood (2x4 scrap)
Large torque wrench can come in handy too
You'll REALLY want the service manual. Trust me.
And here's a rough set of directions (it's been a bit so don't sue me if I forgot something...)
1) SET THE PARKING BRAKE
2) Jack up the front end of the car, set on stands.
3) Jack up the rear of the car, set on stands (skip this step if only doing front pads.)
4) Remove both front wheels. This is where the impact wrench comes in real handy.
5) Remove the 2(?) bolts holding the brake caliper to the brake pad bracket.
6) Remove the old brake pads. This may take a bit of "persuasion" with the hammer and tool of prying. Don't try to force them, you don't want to damage anything down there.
7) Set in the new brake pads. Check with the directions that come with them to make sure you get the right side on the right side. There may be a spring clip that needs to be replaced, can't remember for sure right now.
8) Using the C clamp and a block of wood, push the brake caliper back in so it'll fit around your new pads. Place the block of wood flat against the caliper piston, clamp the C clamp with one pad against the block and the other pad against the back of the caliper housing. Tighten the clamp til the block's flush with the housing. Remove C clamp and block.
9) Squirt the No-Squeal stuff between the pads and pad liners (if there are any, if not see if you can use the old ones)
10) Replace the caliper over the new pads and tighten the bolts. I don't know the proper torque any more but it should probably be somewhere in the area of 30-45 ft/lbs if I remember correctly.
11) Put the front wheels back on.
12) Let the car down off the stands/jack.
13) Turn the car ignition to ON (do not start) and pump the brake pedal smoothly ALL the way to the floor 10-12 times. This should get progressively harder to do as the calipers work their way back snug with the pads. For the last couple, push the brake pedal down and leave it there for a few seconds. This should help equalize pressure across the lines.
14) TEST YOUR BRAKES WHILE GOING SLOW with one hand on the E-brake if necessary.
15) Remove everything not fastened down from the car
16) Bed your new pads: On an empty stretch of road, do 5 stops from 20-5 mph with normal acceleration between them to warm up the pads, then do a series of 10 hard stops from 60-5 mph with normal to spirited acceleration between them. Don't lock the tires up when you brake but run the edge of doing so. The goal is to get the brakes HOT so the new pads bed correctly. Towards the end of the 60-5 mph stops, you should start to smell the brakes. This is normal, as this means they're getting hot and bedded properly.
17) After doing the hard stops, drive for at least another 5 minutes to cool your brakes & pads down. NEVER EVER EVER EVER stop hard then keep the brakes pressed down while the car is not moving. This will transfer a layer of pad material to the rotors and in severe cases you'll be able to see a pad outline right on the rotors from the material transer. This will make your brakes shake and pull badly. BADBADBADBADBADBADBADBAD!
18) Congrats, you're done. Go home & get a beer!
That's a fairly concice list and should roughly cover everything you need. Sorry no pics, like I said it's been probably 8-9 months since I did this myself so this is the best detail I can remember. Hope it helps!
