Status
Not open for further replies.
61 - 71 of 71 Posts
Ha Ha
Nice Ill have to scan the one from my Service manual to top that...just kdding! I was going to post that to but I figured people would ask if they needed it since alot of people arent that techie. I must though that service manual is a god sent...worth every penny and only $80...I love Ebay.
Need a page from Helms (Service) manual - Amplifier Diagram
Hello-
I've got a 2008 Element SC and am in need of the OEM stereo amplifier wiring diagram. Specifically I need the wire colors for the speaker inputs and outputs. If someone has a manual and can scan that page I would greatly appreciate it.
Thanks in advance!
-Brad
Yes - this is EXACTLY what I need- thanks!
Can you tell me a little more about the "shield ground" for the low level amp signal? I'm using a Polk Momo 4-channel amp and caught my signal inputs from the radio to the amp (low level) but am experiencing some engine noise.
Any suggestions?
-Brad
The factory wires are part of a shielded cable which is grounded to prevent interference. Where did you tap into the wires, behind the radio or at the amp? This guy is having a similar problem. http://www.elementownersclub.com/forums/showthread.php?t=52345
Stock Harness Diagram (2008 EX)
I've been searching and can't find the post with the picture of the back of the stock head unit with the callouts for the plugs and what each wire is. There's the one stick with the pinouts for the main harness, but I need to know which is the xm, sub, input, and all that jazz. Thanks.
Save
61 - 71 of 71 Posts
Status
You have insufficient privileges to reply here.
