Hey! I just bought a NOS OEM fog light kit for my '05 EX.
Unfortunately the kit doesn't come with the switch. The instruction booklet says that the switch is "sold separately". This is a nuisance because the kit has the complete wiring harness so essentially it's a "plug and play". I noticed that the switch connector on the harness is 5-pin and the cheap aftermarket switches are only 3-pin. Does anyone have a wiring diagram of the switch harness so I could properly select the 3 pins on the OEM connector to wire into an aftermarket switch?
