Question for the gurus
1.5K views 8 replies 3 participants last post by  Mcdirtymetal
#1 ·
Have a touch screen in dash nav bluetooth double din yadda yadda installed with Metra harnesses. I put it in years ago and have been putting off this problem since.
Here's what happens: if I hit a bad bump, power cuts out and unit reboots. One of those bumps that ruins your suspension. Hard braking or acceleration or hard turns will cause all sound but the sub to cut out. Just the bass stays.
These problems occur when in radio, BT audio or CD/DVD mode. Phone calls too.
I thought I heard that the Metra harness was problematic but couldn't find anything on here. Am I looking at 2 separate wiring issues? (Harness is soldered in, FWIW.) Are the pin outs bad on the harness? I haven't opened it up yet, just wanted to hear from you guys.
#2 · (Edited)
As a veteran installer of 15+ years, I have never had a problem with a Metra harness that wasnt a result of user error, and I have personally installed thousands of head units. Not saying they are flawless, but they have one hell of a track record in my eyes.
Your issue sounds very much like a loose connection. I would start by taking the deck out but leaving everything connected & with the key on and the system playing start wiggling around the wires and plugs to see if you can replicate any of the symptoms (& observing what you did to cause the symptom).
Also look for any cuts or kinks in the wiring that could be causing a short circuit to ground, there is a lot of very sharp exposed steel inside the dash.
If everything passes those tests I would question the condition of the deck itself. A cracked solder joint somewhere inside the HU could cause this, and if the device has one cold joint it likely has many. With the deck in your hand & playing give the side & bottom a firm & solid smack with your palm, see if that does anything.
#3 ·
The bass staying on is because they run through RCA and obviously those connections are good. As stated just pull the deck out with the power on and music playing and have a wiggle. The culprit will soon reveal itself. You may have squished the wires when you put the deck back in. I know in mine I had to really squeeze the harness and all the RCA and Video out cables to have them fit comfortably.
Have you had the deck out at all since install? It's a 5 minute job to pull it out and do some testing.
Berz out.
#9 ·
Found a couple threads with my same problem. I wasn't really being clear enough before. When it cuts to just bass, I meant just the sub is working. Speakers are dead.
Found possible contact marks on inner door shell. Laid down some duct tape and will wait to see if problem arises.
I was leaning towards the amp being bad til I saw that thread.
