So, I did some more research on this... anyone think that a Pilot rear differential assembly would work in an Element? I have been looking at the 2007 Pilot service manual and the electrical diagrams. One could easily hack/modify the rear differential system on the Pilot to control engagement if it were to be mounted. I dunno about anytime of AWD action, though the manual seems to indicate that the VTM-4 system is its own module but it has an F-CAN interface so you would have to interface into the F-CAN system in order for it to work properly. Maybe. Depends on which signals it actually gets from the PCM as the VTM-4 module has its own inputs/outputs in regards to engine speed, TPS, wheel speeds, etc.
Also, the VSA is part of VTM-4. Doesn't the new Elements have VSA, thereby meaning that they are F-CAN as well? So, maybe a rear differential swap from a 2007+ Element will give one the electronically controlled one? I am thinking this is so as VSA needs control of the rear differential to control the wheels. The system in my 2004 can't do that as its strictly a hydraulic coupling system.
