101 - 103 of 103 Posts
Daytime Running Light Mod for the Honda Element
To bh241, it's been 16+ years since you started this thread, so I'm not expecting an answer... but after reading through, I don't believe you talked about the tightness of the workspace in the fuse box area where the connections are made. My friend prepped everything as you described, but when it came to installation, we were left wondering how in the world you're able to reach inside there to perform the work??? Is there a secret to it? Did you have to dismantle half the dash?
Thank you, Rob
When the ignition switch is in the “RUN” position, the headlight switch is in the OFF position, the parking brake is not set, power is applied to the coil of relays 2 through 5 through the contact of relay 1.
