Good Ole Flashing Green Drive Light
Hooray! Two weeks after fixing the V-Tec Oil Pressure Switch (which i found the solution and instructions on this site, thank-you very much!!!) the Green Drive indicator has started flashing. Based on what I have read here, and the fact that I am broke, I began to play around. My E is driving perfect, no lurching, no weird shifting, no overheating, and no computer codes on my code reader. I checked the tranny fluid, which is scheduled to be replaced soon as I am almost at 200k, and it is full and red with no weird smell! I think it might be a malfunctioning sensor. I did some test driving on the way home yesterday. Typically, the light comes on within 500m of driving every time the ignition is turned off. I drove it about 2k at low speed in first, no light. Switched to second gear for about 2k, no light. Went into 3rd gear (OD off) on the highway for 10k, no light. Hit the OD button, within 5 seconds, the light started flashing. The car accelerates on the highway with no problem, nice and smooth, and runs great in OD as well. Could this just be because I am close to 200k and the tranny fluid change, or could it be a sensor. Any advice? Again, I have to keep the service bill extremely low, as I just came off of EI benefits. This forum saved me a fortune last time (600 for vtec and code reading from the dealer, 106 dollars when I borrowed a code reader and changed it myself) and I am hoping to do it again!
Thank-you!
